Measuring the IOM Mainsail
Moderator: Lawrie Neish
Sail number: SWE 58
Club: SRSS
Design: Kantun S
Post by magnusmodig » 26 Apr 2016, 13:47
Hello IOM lovers,
Since I am planning to manufacture IOM sails just for fun I would like
somebody to again confirm the exact rule of measuring the main sail.
I find 2 different way of doing it on the internet.
1. To find the leach 1/2 point you use the method of Lester above.
The mainsail leach midpoint is found when you draw a 90 degree
line from the midpoint of a strait line between the forward Head point
and the Clew point.
2. The leach 1/2 point is found as the mid point if you fold the sail holding
the aft Head point and Clew exactly aligned. This is the exact leach 1/2 point
Whick one is the correct one ?
Since the IOM mainsail leach does not bend much the result is almost
the same. The difference is only a few millimeter.
When I measured my existing sails they were approved with either
When I got my sails approved by a measurer guy he used method 2.
Still I would like someone here to confirm what method 2 SHOULD be used.
I put this question on the international IOM facebook group.
I though I would get the correct answer within 15 minutes.
NOBODY answered !!!
Thanks in advance
Magnus Modig
CHATIN Achille
Sail number: FRA 16
Club: CV Cazaux Lac
Re: Measuring the IOM Mainsail
Post by CHATIN Achille » 09 Jun 2016, 10:19
Last but not least, as there is no answer, here is mine with little experience even if I am not an official ISAF measurer ;-)
As far as I know, Method 1 is the right one. Then to find 1/4 points you repeat the same method from the 1/2 origin founded on the edge of the sail.
Is that clear enough ?
