Graupner vs RMG sailwinch
Moderators:GaryBoell, Pedro Egea
Cort Steck
Sail number:USA
Post by Cort Steck » 20 Oct 2010, 22:02
Can anyone tell me the pros and cons of the Graupner and RMG winches. I see that the Graupner is lighter than the RMG and less expensive. How does its performance compare to the RMG. Any other good winches out there.
Sail number:GBR3845
Club:Eastbourne
Design:TS2 and Shiraz
Re: Graupner vs RMG sailwinch
Post by Dave Pickett » 20 Oct 2010, 22:17
Well this one (after a bit of searching on the web) appears to produce more torque than the Graupner
http://www.servoshop.co.uk/index.php?pi ... area=Servo
no personal experience but surely worth trying at the price (£15!) I am going to get one for my Nylet spirit, so much cheaper than the others!!!
Graupner = 4.6 kgcm, supertec =6.6 kgcm
Post by Andy Stevenson » 21 Oct 2010, 10:15
Careful with the T125, I'm lead to believe it's limited to just one turn.
Sail number:GBR3845
Club:Eastbourne
Post by Dave Pickett » 21 Oct 2010, 19:19
if it has more torque its likely to be lower geared and thus have more turns, are you certain it only does one turn?
Post by Andy Stevenson » 21 Oct 2010, 19:27
Dave Pickett wrote:[...]are you certain it only does one turn?
Pretty sure, although I've never actually used one. They pop up on ebay from time to time.
Hiljoball
Sail number:CAN 307
Club:West Coast Radio Sailing
Design:V8
Post by Hiljoball » 21 Oct 2010, 19:48
For an inexpensive sail winch, the Hitec HS 815 arm winch is a bargain. lots of travel (about 140 degrees), fast, powerful and very reliable at just $50. It weighs a bit more than the latest digital servos but is not heavier than an RMG. The HS785 drum winch at the same price has the power and the turns but is a bit slow for competitive racing.
Sail number:CAN 46
Club:VMSS
Design:V8
Post by Barry Fox CAN262 » 22 Oct 2010, 21:07
I seriously doubt that T125 is going to do the job in any but the lowest wind ranges. I found a drum servo that is pretty much exactly the same as the Hitec 785 drum winch for a lot less at:
http://www.hobbypartz.com/12exiseb1.html
It is not any faster than the Hitec one but once you get used to the speed, and learn to anticipate a bit on sail adjustments, it is quite acceptable for any club level sailing. I have used the Hitec ones on other boats and they have no real problem pulling in the sails in higher ranges. The one advantage of the slightly slower speed is that you do not have the problem with stalling your sails when you sheet in as you round the leeward marks.
Gyula
Sail number:ROU 52
Design:Ska
Post by Gyula » 22 Oct 2010, 23:19
Anyone tried the Eurgle winches?
I use a Graupner regatta on my Triple Crown and it works OK. First I had an RMG in it, but later I put the RMG in a Marblehead.
The RMG was faster and probably stonger, but the Graupner is OK too.
Gyula Ferencz
Sail number:GBR3845
Club:Eastbourne
Post by Dave Pickett » 23 Oct 2010, 10:09
Good call on the Eurgle winches, I'll get one of those for my spirit especially as Kbits are just down the road!!
(you do need a tx with end point adjustment, but I am intending to get a spektrum D6i)
