RMG Winch set up....
Posted: 22 Oct 2014, 17:43
This may be of help to some folk, many at my local club are not keen of the programmable aspect of the RMG as it is viewed this days as largely unnecessary since the built in EPA adjustment on modern TX's is far easier to work with.
On my TS2 the winch overides my TX which I find really annoying so I was looking at finding a better set up on my new Sharaz, especially as the RX is buried away inside the radio pot, so here's what I ended up doing:
- Set the EPA on both full in and out at 120%
- Took the drum off the winch and program the winch to accept these end points, it is also necessary to move the sheets full in and out for the winch to accept the settings.
- Put the TX EPA own low - 60 - 80% is a safe margin
- Start TX and then the RX and centralise the stick/winch
- Put the drum back on at midpoint
- It is now possible to sheet in and adjust the full in point on the TX EPA as required, repeat with the sheeted out position.
I am sure many will have figured this out, but it may just help someone out there!
