Posted: 14 Nov 2004, 03:00
by Ralph Knowles
Hi Bfox1,
The rule of thumb appears to be that if the part can move, or be moved, then it is not part of, or, a structural member of the hull. Therefore the steering rod, rudder,keel fin, servo arm, or a movable part of the sheeting post are allowed to be of carbon construction. The likes of the fixed part of the sheeting post, rudder tube, or anything else fixed such as the servo tray, even though it may be unshipped, are deemed to be structural parts as they are fixed directly to the hull and/or deck.
Hope this clears up this point.
I had the same problems refurbishing an old Mandarin IOM a few of years ago which had been built with some fixed carbon bits. I am now legal.
Posted: 14 Nov 2004, 23:20
by Roy Thompson
I can't be absolutely sure, but I recall something about carbon rudder posts are ok if they're not fixed top and bottom to the hull (as in skiff type hulls that have the rudder link outside the hull not internal) since they don't affect the strength or structural stability of the hull. I think this maybe an important point but I can't remeber exactly where I saw this discussion.
