A mast and a spar,
A checkstay and a shroud,
A jackstay and a mast jack.
I can't understand the rules!
- USA NCA Officer
Sailing Terms
James,
I say, keep at it, the recommendations of the other sailors are sound, the best way to learn is to read up and read up and of course actually go out and see for yourself. I have been sailing for quite some time now, both real boats and RC boats and I can only answer half or less of your questions. The problem is that sailing terms can vary from one place to the other and other terms can be used for a different thing altogether.
I will stick my neck out and try to answer some of your questions but don't take them to be 100% correct though. I hope you forgive me though when I say that I think some of your questions you really don't need to know anyway I don't and still get to sail no problem hehehe! Also please do understand also that some of these terms are not really necessary for RC models.
I hope this helps.
Cheers.
I hope this helps.
Cheers.
Murray Buckman
USA 274
USA 274
