Hull length + draft
Posted: 24 Feb 2005, 05:42
Having read thru the Class rules 2003 v.2
The hull length is stated as 1000mm, is this the overall length of the hull from bow to stern?
The reason I am asking is I have a Ragtime hull which I am in the process of assembling.
There is a rake on the Bow of +/- 5degrees.
When I measure her overall length it is 1000mm, when I measure her on the waterline it is 993mm.
Also is the 10mm bumper included in the 1000mm measurement.
The draft is to be 370 to 420mm, is this measured vertically from the lwl along the chord of the keel to the bottom of the lead.
I do not want to build her only to to have to take her apart for some silly infringement.
Having not built a 1M before (only RM's) any assistance would be much appreciated.
Ray
