AGM Resolution proposal: WC_AGM2006_04
Posted: 17 Jul 2006, 10:04
[quote]Resolution:
WC_AGM2006_04
Proposing NCA / WC Member:
Steve Landeau, NCA for USA
Proposal:
Subject: Added Weights
Rule C.7.3(a)
Change to: “Weights may be positioned in or on a mast spar. If the weight is to be internal, it shall be installed at the lowest point possible. “
Discussion:
With a deck-stepped mast, you only have approximately 60 mm to insert lead weight internally. The #3 rig can require as much as 140 grams of corrector weight. Only about 60 grams of this will fit inside, and below the lower band. Eliminating this part of the rule would not enhance the performance capabilities of the boat. The only benefit gained would be a cleaner and simpler way to facilitate the installation of the weight and meet the minimum weight requirement while using the “câ€
[quote]Resolution:
WC_AGM2006_04
Proposal:
Rule C.7.3(a)
Discussion:
