Mr Graham Elliott
Sail number: 09
Club: Birkenhead
Design: britpop
Post by Mr Graham Elliott » 20 Nov 2020, 17:04
Post by Lester » 20 Nov 2020, 18:01
Post by RoyL » 20 Nov 2020, 21:08
Hiljoball
Post by Hiljoball » 20 Nov 2020, 23:21
2D.1
Mr Graham Elliott
Sail number: 09
Club: Birkenhead
Design: britpop
Post by Mr Graham Elliott » 21 Nov 2020, 00:15
Post by RoyL » 22 Nov 2020, 01:31
SEBASTIEN LEFEBVRE
Post by SEBASTIEN LEFEBVRE » 22 Nov 2020, 10:38
I had printed 3 iom boats.
Sébastien LEFEBVRE
Chris Elliott
Sail number: 74
Club: Lincoln
Design: Britpop
Post by Chris Elliott » 22 Nov 2020, 10:53
Let me put my views on this:
Chris.
Torsten Kass
Sail number: GER 75
Club: VdMYS
Design: Incognito
Post by Torsten Kass » 22 Nov 2020, 11:47
Hallo, ich bin der Neue... :D
Kommen wir aber zu Thema:
Es gibt nur eine Einschränkung für die Filamente - kein Carbon - Ende der Ansage. :P
Chris Spalding
Sail number: 87
Club: Keighley
Design: Sabre
Post by Chris Spalding » 22 Nov 2020, 12:51
Post by Lester » 22 Nov 2020, 13:06
Torsten Kass wrote:
22 Nov 2020, 11:47
Courtesy of Google Translate:
Hello, I'm the new one ...: D
But let's get to the topic:
Torsten Kass
Sail number: GER 75
Club: VdMYS
Design: Incognito
Post by Torsten Kass » 22 Nov 2020, 15:38
Ist aber nicht wichtig.
@Lester
Post by Lester » 22 Nov 2020, 15:57
Torsten Kass wrote:
22 Nov 2020, 15:38
Google translate:
But it is not important.
@Lester
Gabriel Le Duc
Sail number: FRA 08
Club: Club Nautique Cap d'Agde
Design: Le Duc Gabriel
Post by Gabriel Le Duc » 22 Nov 2020, 20:13
Gabriel Le Duc
Gabriel Le Duc
Sail number: FRA 08
Post by Gabriel Le Duc » 22 Nov 2020, 20:15
Now in Google English
Gabriel Le Duc
Juan Marcos Egea
Post by Juan Marcos Egea » 23 Nov 2020, 13:42
What we see happening:
My conclusions about rules:
Richard Moroney
Sail number: GBR4351
Club: Leicester RYC
Design: Alternative
Post by Richard Moroney » 23 Nov 2020, 17:02
Richard
Richard
Narrowseas
Vice-chairman (Technical)
Sail number: CRO 68
Club: JK Opatija
Design: Kantun 2
Post by Robert Grubisa » 23 Nov 2020, 17:09
Mr Graham Elliott wrote:
20 Nov 2020, 17:04
Graham,
All the best
Robert Grubiša
CRO 68
Sail number: CRO 68
Club: JK Opatija
Design: Kantun 2
Post by Robert Grubisa » 23 Nov 2020, 17:20
Hiljoball wrote:
20 Nov 2020, 23:21
2D.1
John,
All the best
Robert Grubiša
CRO 68
PS Original typo corrected.
Sail number: CRO 68
Club: JK Opatija
Design: Kantun 2
Post by Robert Grubisa » 23 Nov 2020, 17:27
the base material.
Graham Bantock
* author emphasis added
end
Sail number: CRO 68
Club: JK Opatija
Design: Kantun 2
Post by Robert Grubisa » 23 Nov 2020, 17:32
Robert Grubiša
CRO 68
Sail number: CRO 68
Club: JK Opatija
Design: Kantun 2
Post by Robert Grubisa » 23 Nov 2020, 17:33
Juan Marcos Egea wrote:
23 Nov 2020, 13:42
Hi Juan Marcos,
Full agreed with your post.
Robert Grubiša
CRO 68
Mr Graham Elliott
Sail number: 09
Club: Birkenhead
Design: britpop
Post by Mr Graham Elliott » 23 Nov 2020, 21:11
Sail number: CRO 68
Club: JK Opatija
Design: Kantun 2
Post by Robert Grubisa » 23 Nov 2020, 21:31
23 Nov 2020, 21:11
Graham,
Robert Grubiša
CRO 68
Post by Lester » 23 Nov 2020, 21:47
The question
Conclusions
Laws of physics.xlsx
Excel file
(12.08 KiB) Downloaded 5491 times
3D printing.pdf
PDF file
(491.09 KiB) Downloaded 5712 times
Mr Graham Elliott
Sail number: 09
Club: Birkenhead
Design: britpop
Post by Mr Graham Elliott » 23 Nov 2020, 22:54
USA NCA Officer
Post by Bruce Andersen » 24 Nov 2020, 00:55
Sail number: CRO 68
Club: JK Opatija
Design: Kantun 2
Post by Robert Grubisa » 24 Nov 2020, 13:51
Lester wrote:
23 Nov 2020, 21:47
Conclusions
Thanks for interesting article. I am not questioning the law of physics at all :wink: but take into consideration the following assumption.
What if somebody conclude that the current "traditional" :wink: moulded glass/epoxy hulls are simply unnecessary stiff and long-lived and that for the top results you don't need such "extra stiffness" and that the risk of collision and total loss of the boat is not so high.... And that such skipper manage to make a hull using new technologies (one of them is 3D printing). Note, building techniques are not restricted..... And that such skipper/builder produce the hull with different thickness of hull skin so the ends are lighter than the middle part of the boat. And that some XYZ commercial manufacturer is starting to advertising and selling such IOM boats as the state-of-the-art product using the latest additive manufacturing etc etc in compliance with the IOM Class Rules. Do we want that? I don't.
All the best
Robert Grubiša
CRO 68
Torsten Kass
Sail number: GER 75
Club: VdMYS
Design: Incognito
Post by Torsten Kass » 24 Nov 2020, 16:06
Noch eine wichtige Sache:
Post by Lester » 24 Nov 2020, 16:47
Robert Grubisa wrote:
24 Nov 2020, 13:51
What if [...] the hull with different thickness of hull skin [...] advertising and selling such IOM boats as the state-of-the-art?
Hi Robert
24 Nov 2020, 13:51
[...] honeycombing (infill) is not allowed because if it is allowed for 3D printed boats why to prohibit it on the moulded boats?
Prohibited for moulding because the 3D printed hull is thermoplastic, whereas the moulded hull is thermoset.
24 Nov 2020, 13:51
I don't understand why this is a "loophole". I can see no problem to have a 3D printed thermoplastic honeycomb which is a core between two layers of glass fibre skin. Thermoplastic is much weaker than almost any other material of interest, and the only way to get strength and stiffness is to make it thick. When thick, it is heavy, so we honeycomb it. The laws of physics tell us that a honeycombed thermoplastic is somewhere between twice and four times as heavy as a thin material for equivalent strength and stiffness. But I will check this, I can construct and test a desktop model of a 3D printed honeycombed nylon sheet between two thin g/f sheets and let you know the outcome.
