Moderators: Gary Boell, Pedro Egea
Sail number: CRO 68
Club: JK Opatija
Design: Kantun 2
Post by Robert Grubisa » 24 Jan 2021, 13:30
Hi Graham,
All the best
Robert
Art Prufer
Sail number: CAN 42
Design: DC7
Post by Art Prufer » 01 Feb 2021, 00:49
Art Prufer
CRYA #1189 Can 42
Sail number: CRO 68
Club: JK Opatija
Design: Kantun 2
Post by Robert Grubisa » 01 Feb 2021, 07:59
Hi Art,
All the best
Robert Grubiša
CRO 68
Hiljoball
Post by Hiljoball » 01 Feb 2021, 18:50
Hi Robert,
Sail number: CRO 68
Club: JK Opatija
Design: Kantun 2
Post by Robert Grubisa » 02 Feb 2021, 15:32
Hi Hiljoball,
You mentioned that the proposal "changes the philosophical structure of the Materials section in a very significant way – with possible ‘unexpected’ consequences." Sorry, this sounds to me like some political phrase ;-)
Robert Grubiša
CRO 68
Art Prufer
Sail number: CAN 42
Design: DC7
Post by Art Prufer » 02 Feb 2021, 18:25
3) Reasoning for the proposed IOM Class Rule
I did not see any discussion with the IOM global community regarding this proposed change, at least not on this forum or on any of the other IOM sailing forums.
Art Prufer
CRYA #1189 Can 42
Hiljoball
Post by Hiljoball » 18 Oct 2021, 23:24
Design: Britpop
Post by Olivier Cohen » 20 Oct 2021, 12:54
