Page 3 of 4
Re: Single Panel Molded Sails
Posted: 11 Jul 2011, 10:37
by Alfonso
Hi Bruce,
Posted: 11 Jul 2011, 15:11
by TedFlack
Posted: 11 Jul 2011, 18:29
by Bruce Andersen
Thanks for asking.
Posted: 11 Jul 2011, 22:02
by Alfonso
Hi Bruce,
Posted: 11 Jul 2011, 23:13
by Bruce Andersen
Alfonso
Posted: 11 Jul 2011, 23:18
by John Ball
Posted: 11 Jul 2011, 23:39
by RoyL
Posted: 12 Jul 2011, 02:16
by Barry Fox CAN262
Posted: 12 Jul 2011, 09:39
by Alfonso
Hi John,
Posted: 12 Jul 2011, 12:13
by Dave Alston
Gentlemen,
and retaining
Dave A
Posted: 12 Jul 2011, 15:27
by TedFlack
Alfonso wrote:Hi John,
I've been thinking :roll: : Perhaps the only way to settle this sails issue (if we have one) is by controlling the material that is used to make them.
Posted: 12 Jul 2011, 16:40
by Peter Allen
Posted: 12 Jul 2011, 18:39
by John Ball
G.3.1 CONSTRUCTION
(a) MANDATORY
and
G.3.2 CONSTRUCTION TECHNIQUES
beyond the edges of the seam.
How does this approach work?
Posted: 12 Jul 2011, 20:44
by TedFlack
Peter Allen wrote:Ted,i hear what you're saying but i don't know what you're thinking. Peter
Peter,
Ted
Posted: 13 Jul 2011, 08:50
by Alfonso
Hi John,
Posted: 13 Jul 2011, 19:17
by Dave Alston
Ted
Alfonso
Gentlemen
Posted: 13 Jul 2011, 19:56
by John Ball
Hi Dave,
Posted: 13 Jul 2011, 21:05
by TedFlack
Dave,
Ted
Posted: 14 Jul 2011, 01:17
by Dave Alston
Ted,
But I digress….
Posted: 17 Jul 2011, 16:17
by RoyL
Posted: 20 Jul 2011, 09:26
by Dave Alston
Roy,
Posted: 20 Jul 2011, 09:38
by Dave Alston
Posted: 20 Jul 2011, 11:01
by Antonio Espada
Antonio.
Posted: 30 Aug 2011, 18:32
by Robert Grubisa
Hi all
Posted: 31 Aug 2011, 18:26
by Don Case
Can224
Zvonko wrote:Dear all
Posted: 01 Sep 2011, 17:20
by Barry Fox CAN262
Hi Don,
Just a guess.
Posted: 01 Sep 2011, 18:56
by John Ball
Posted: 02 Sep 2011, 09:50
by Nigel
Hi John,
Posted: 02 Sep 2011, 16:38
by Dick Carver
Nigel wrote:Hi John,
Agreed.
Posted: 03 Sep 2011, 07:09
by RoyL
