Posted: 07 Nov 2024, 10:27
by Stephen Robinson
Posted: 13 Nov 2024, 22:42
by Bruce Andersen
Posted: 14 Nov 2024, 07:04
by Stephen Robinson
Thanks Bruce.
Posted: 14 Nov 2024, 17:07
by Bruce Andersen
Posted: 15 Nov 2024, 04:23
by Stephen Robinson
Bruce Andersen wrote: 14 Nov 2024, 17:07 If you're determined to use a switch, use a SmartSwitch from RMG - it is sealed, shows battery charge status at a glance, and is flat to eliminate line snags
Thanks. Will have a look.
Posted: 18 Nov 2024, 13:35
by Olivier Cohen
Posted: 19 Nov 2024, 06:03
by Stephen Robinson
Olivier Cohen wrote: 18 Nov 2024, 13:35 When I had an armwinch with battery connected directly to the receiver, I used a wire connected to the receiver with on the other side a plug such as XT60 to connect my battery on it. As you say, less dangerous for receiver's pins.
Thanks Oliver.
Posted: 09 Dec 2024, 17:28
by Art Prufer
Posted: 12 Dec 2024, 05:25
by Stephen Robinson
Thanks Art. :D
