Voltage indicator / battery indicator legal?
Post by Lester »
In common with a number of owners, I've fitted Rob Guyatt's little battery voltage flashing display thingy on my pot lid (http://www.onemetre.net/OtherTopics/Flash/Flash.htm). Turns out this might not meet the IOM class rules:
(1) One receiver.
(2) One rudder control unit.
(3) One sheet control unit.
Post by Steve Landeau »
Hi, Lester.
Post by Barry Fox CAN262 »
Gilbert Louis
voltage reader
Post by Gilbert Louis »
Hi,
Gilbert
Gilbert LOUIS
www.iomireland.org
V6 - RMG - Blackmagick
IRL41 - Ireland
Post by RoyL »
Voltage Meter
Post by Ken Dobbie »
Ken
Post by Alfonso »
I agree 100% with Ken.
JThompson
Post by JThompson »
Jim
Jim Thompson
IOM - USA 370 - Ericca
Post by John Ball »
Post by RoyL »
Gilbert Louis
voltage reader
Gilbert LOUIS
www.iomireland.org
IRL41 - Ireland
Post by RoyL »
paulo gomes
Sail number: POR56
Club: Clube Naval Povoense
Design: BritPop
Post by paulo gomes »
Hello from Portugal,
Our very best regards
APMV
Portugal
Post by Olivier Cohen »
100% OK with that
Post by Andy Stevenson »
Hi Paulo
Hi Steve
Post by John Ball »
Post by RoyL »
Post by Alfonso »
Stefano Savelli
ITA NCA Officer
Post by Stefano Savelli »
hello to all,
Stefano Savelli (Ita54)
Stefano Savelli
SAVELLI S.r.l.
Via Bergamo 2/1a
23875 Osnago (LC)
Post by Don Case »
Post by John Ball »
C5.3
