- Sail number: GBR3845
- Club: Eastbourne
- Design: TS2 and Shiraz
And how long do they last?
- Sail number: us 462
- Club: NBRCSC
- Design: errica
stats - 2s2p cells
3.2 oz/90.7g
50x30x31mm
sully
stats - 2s2p cells
3.2 oz/90.7g
50x30x31mm
sully
- USA NCA Officer
- Club: Eastbourne
- USA NCA Officer
- Sail number: CAN 46
- Club: VMSS
- Club: VMSS
I'm happy.
I'm happy.
- USA NCA Officer
- USA NCA Officer
- Club: Eastbourne
- Club: Eastbourne
- Sail number: ROU 52
- Design: Ska
Gyula Ferencz
- Club: Eastbourne
- Club: Eastbourne
Peter,
I am using this one:
- Club: VMSS
- Club: VMSS
- Club: Eastbourne
Guys,
To confirm for total clarity
- Club: VMSS
