Sheet winches
Nigel28
- Sail number: CAN 28
- Design: Vancouver
Sheet winches
Nigel Ashman
CAN 328
CAN 328
Greg Vasileff
There are 2 kinds of 5801 owners,Greg Vasileff wrote:......Futaba s5801.....
I know there has been some bad rap on these, but I use 5 of them now, some for three years, and I've never had any problems.
Brad Gibson
Hi Ed,
As allways it comes down to personal preference (& what can be easily fitted to your hull
BG
BG
sheet winches
hi ed,
ron
ron
Jeff
Jeff
