Sail number: GBR3845
Club: Eastbourne
Design: TS2 and Shiraz
Post by Dave Pickett » 08 May 2011, 12:18
And how long do they last?
Post by John Ball » 08 May 2011, 18:06
chris sullivan
Sail number: us 462
Club: NBRCSC
Design: errica
Post by chris sullivan » 08 May 2011, 18:27
stats - 2s2p cells
3.2 oz/90.7g
50x30x31mm
sully
Post by Bruce Andersen » 08 May 2011, 22:22
Peter Allen
Post by Peter Allen » 15 May 2011, 03:45
Peter Allen
Post by Peter Allen » 15 May 2011, 04:14
Club: Eastbourne
Post by Dave Pickett » 15 May 2011, 08:13
Peter Allen
Post by Peter Allen » 15 May 2011, 13:03
Post by Bruce Andersen » 17 May 2011, 02:03
Post by Barry Fox CAN262 » 17 May 2011, 05:56
Peter Allen
Post by Peter Allen » 17 May 2011, 12:15
Post by Barry Fox CAN262 » 17 May 2011, 19:14
I'm happy.
Post by Bruce Andersen » 19 May 2011, 01:33
Peter Allen
Post by Peter Allen » 19 May 2011, 16:24
Post by Bruce Andersen » 21 May 2011, 05:48
Club: Eastbourne
Post by Dave Pickett » 09 Jul 2012, 10:59
Peter Allen
Post by Peter Allen » 09 Jul 2012, 12:53
Peter Allen
Post by Peter Allen » 09 Jul 2012, 13:38
Peter Allen
Post by Peter Allen » 12 Jul 2012, 19:11
Club: Eastbourne
Post by Dave Pickett » 13 Jul 2012, 10:38
Gyula
Sail number: ROU 52
Design: Ska
Post by Gyula » 14 Jul 2012, 16:20
Gyula Ferencz
Peter Allen
Post by Peter Allen » 16 Jul 2012, 18:23
Club: Eastbourne
Post by Dave Pickett » 18 Jul 2012, 14:46
Peter Allen
Post by Peter Allen » 18 Jul 2012, 16:03
Club: Eastbourne
Post by Dave Pickett » 18 Jul 2012, 20:02
Peter,
I am using this one:
Post by Barry Fox CAN262 » 18 Jul 2012, 23:44
Peter Allen
Post by Peter Allen » 19 Jul 2012, 00:40
Post by Barry Fox CAN262 » 19 Jul 2012, 05:40
Club: Eastbourne
Post by Dave Pickett » 19 Jul 2012, 17:09
Guys,
To confirm for total clarity
Post by Barry Fox CAN262 » 19 Jul 2012, 21:56
