- Mr Graham Elliott
- Sail number:09
- Club:Birkenhead
- Design:britpop
- Sail number:CAN 307
- Design:V8
2D.1
2D.1
- Mr Graham Elliott
- Sail number:09
- Club:Birkenhead
- Design:britpop
SEBASTIEN LEFEBVRE
I had printed 3 iom boats.
Sébastien LEFEBVRE
Sébastien LEFEBVRE
Chris Elliott
- Sail number:74
- Club:Lincoln
- Design:Britpop
Let me put my views on this:
Chris.
Chris.
Torsten Kass
- Sail number:GER 75
- Club:VdMYS
- Design:Incognito
Hallo, ich bin der Neue...
Kommen wir aber zu Thema:
Es gibt nur eine Einschränkung für die Filamente - kein Carbon - Ende der Ansage.
Chris Spalding
- Sail number:87
- Club:Keighley
- Design:Sabre
Torsten Kass wrote: ↑22 Nov 2020, 11:47Courtesy of Google Translate:
Hello, I'm the new one ...: D
But let's get to the topic:
Torsten Kass
- Club:VdMYS
- Design:Incognito
Ist aber nicht wichtig.
@Lester
@Lester
Torsten Kass wrote: ↑22 Nov 2020, 15:38Google translate:
But it is not important.
@Lester
Gabriel Le Duc
- Sail number:FRA 08
- Club:ASBB
- Design:Le Duc Gabriel
Gabriel Le Duc
Gabriel Le Duc
Gabriel Le Duc
- Club:ASBB
Now in Google English
Gabriel Le Duc
Gabriel Le Duc
Juan Marcos Egea
What we see happening:
My conclusions about rules:
Richard Moroney
- Sail number:GBR4351
- Club:Leicester RYC
- Design:Alternative
Richard
Richard
Richard
Narrowseas
Narrowseas
- Sail number:CRO 68
- Club:JK Opatija
- Design:Alioth V4
Graham,Mr Graham Elliott wrote: ↑20 Nov 2020, 17:04Let's all have a discussion in the correct place, the IOMICA forum, and not Facebook or secret emails, yes, an open discussion with even luddites included.
All the best
Robert Grubiša
CRO 68
- Club:JK Opatija
- Design:Alioth V4
John,Hiljoball wrote: ↑20 Nov 2020, 23:21
2D.1
All the best
Robert Grubiša
CRO 68
PS Original typo corrected.
- Club:JK Opatija
- Design:Alioth V4
the base material.
Graham Bantock
* author emphasis added
end
the base material.
Graham Bantock
end
- Club:JK Opatija
- Design:Alioth V4
Robert Grubiša
CRO 68
Robert Grubiša
CRO 68
- Club:JK Opatija
- Design:Alioth V4
Juan Marcos Egea wrote: ↑23 Nov 2020, 13:42Hi everybody, and thank you Graham for the initiative.
Hi Juan Marcos,
Full agreed with your post.
Robert Grubiša
CRO 68
- Mr Graham Elliott
- Sail number:09
- Club:Birkenhead
- Design:britpop
- Club:JK Opatija
- Design:Alioth V4
Mr Graham Elliott wrote: ↑23 Nov 2020, 21:11Yes, just using this open forum to, as I said, 'come to an agreed wording and get the motion passed'.
Graham,
Robert Grubiša
CRO 68
The question
Conclusions
The question
Conclusions
- Laws of physics.xlsx
- Excel file
- (12.08KiB)Downloaded 25472 times
- 3D printing.pdf
- PDF file
- (491.09KiB)Downloaded 27359 times
- Mr Graham Elliott
- Sail number:09
- Club:Birkenhead
- Design:britpop
- Sail number:USA 16
- Design:Brit Pop
- Club:JK Opatija
- Design:Alioth V4
Hi Lester,Lester wrote: ↑23 Nov 2020, 21:47
Conclusions
Thanks for interesting article. I am not questioning the law of physics at all
What if somebody conclude that the current "traditional"
All the best
Robert Grubiša
CRO 68
Torsten Kass
- Club:VdMYS
- Design:Incognito
Noch eine wichtige Sache:
Hi RobertRobert Grubisa wrote: ↑24 Nov 2020, 13:51What if [...] the hull with different thickness of hull skin [...] advertising and selling such IOM boats as the state-of-the-art?
