Following on from my previous post about suppliers of aluminium tube, I’m still following a few leads for suitable tubing, but it’s looking more & more likely I’m going to Sailsetc or Housemartin for my masts.
Now, this will be my first attempt at putting a rig for an IOM together, so I’ll apologise now if any of these questions seem a little daft, but…
Most people seem to be using 7/16â€
Masts
- GBR NCA Officer
Masts
Re: Masts
Hi Andy,
[quote="andy111"]
[quote="andy111"]
- GBR NCA Officer
Re: Masts
Oh, OK. I was kinda getting thereVCinfocomms wrote: The reasoning is that 12.7mm is stiff enough to be used without pre-bend on the no1 rig and for the smaller ones 11.1mm is enough, you would not get any significant gains with 12.7mm on the no2 and no3.
Absolutly agree, backstay tension is about getting a balance between a mast bend to match the mainsail luff & good jibstay tension.I think one of the tricks when setting up an IOM rig is to get as much forestay tension as possible. This is done with swept back shrouds and/or with backstay tension. The problem with exessive backstay tension is that it flattens and distorts the top of the mainsail.
Agreed, I’d like a solution that doesn’t rely on me storing the masts under tension. I think a 1/2â€I also find the concept of pre-bend and having to store rigs tensioned not very nice.
Brig North
