Hi, Marko.
I'm having difficulty going with Lester on this one as well, but I am beginning to understand why it may be intended to work this way.
Allowing the clear ahead boat to tack within the zone causes unnecessary chaos. Usually, if clear ahead wants to tack in this situation, it is to protect her from her own poor rounding. If Blue were to have a "proper" rounding, and tack right away, she would be further upwind and clear of a proper rounding from Green. Since Green never has to anticipate Blue's actions, Green would almost always have to make drastic changes in course should Blue make a maneuvere like this within the zone.
Yes, Blue is on Stb, but if Lester is right, and Green gains protection under 18, Section C takes precedence over Section A, which would protect Green.
This has to be covered somewhere in the case book or appeals. If not, maybe we need to submit it!
I have been to Dave Perry's seminars, and one of the things he tells us is that OUR interpretations of the rule often cloud the rule itself.
In this case, Blue has changed the situation due to her own actions. Rule 18 applies if there is an overlap. The subparts of 18 give exceptions and limitations. Simple 18 is first, subparts next. Since Blue gave up her protection from 18.2(c) by tacking (thus putting Green into an inside overlapped position), and Green is "still rounding", 18 becomes in effect immediately, and 15 also does not apply.
Lester, I hope you are right about this, or else I'll have to start seeing a therapist, and I'm going to send you the bill!!
