Can anyone tell me the area of the main and of the jib of an "A" rig and where(approx) the CE is? I have found 2 or 3 different formulae on the net and in books and each gives a different answer, none of which agrees with my gut feeling that this should be straight forward arithmetic that even I can follow.
PS I'm assuming that the "B" and "C" would have the same(at least horizontal) CE, am I right?
CE and Sail Area
CE and Sail Area
Don Case
Can 271
Vancouver Island B.C.
Can 271
Frednatal
- Sail number: BRA 66
- Design: Xique-Xique
Re: CE and Sail Area
Hi Don
I have some data:
A
main sail Area = 0.34679 m² CE --> XCE = -0.1215 m YCE = 0.610 m
jib sail Area = 0.2458 m² CE --> XCE = 0.1258 m YCE = 0.4760 m
Jib + Main --> Area = 0.593 m² CE --> XCE = -0.019 m YCE = 0.554 m
B
Jib + Main --> Area = 0.426 m² CE --> XCE = -0.023 m YCE = 0.412 m
C
Jib + Main --> Area = 0.272 m² CE --> XCE = -0,037 m YCE = 0.313 m
The reference for X is mast position (negative aft), for Y is the foot of sails, considering that foot are in same level.
Is not sails with total maximum permitted area.
Fred
I have some data:
A
B
C
Fred
Fred Schmidt
Thank you Fred
It amazes me how tough it was to find this information. I would have thought it would be common knowledge. Maybe everyone was thinking," Figure it out yourself, I had to." I did roughly figure it out myself and my results are close to yours, so I'm happy.
I went and looked at your website and it looks very interesting. There doesn't happen to be an English version of the articles, does there? I tried Babelfish and it left a lot to be desired.
Thanks again
Thanks again
Don Case
Can 271
Can 271
Frednatal
Hi Don
My site is exactly for this: share knowing. I can help and I am helped. It is exclusively technical. I had many difficults to learn about IOM and I do not like that peoples pass by the same.
If you have interest in some post, call me that I translate for you. If some people believe that the site has interest I can do an English version.
I have a spreadsheet that calculate the sail areas and CoG, but the Forum do not accept spreadsheets extensions, but I can send to you by e-mail
fred
fred
Fred Schmidt
Hi Fred
I tried a Google translation instead of Babelfish and it is much better so you needn't translate. You wouldn't have the static numbers for any other IOM's would you?
Don Case
Can 271
Can 271
Frednatal
Hi Don
Unhappy I do not have. Would be interesting if we could have. If someone has a table of offsets and want know resistance by Michelet, inclined waterlines, Turner's Moments, righting arm and accept make the results available for all I can do the work.
Fred
Fred
Fred Schmidt
