Single Panel Molded Sails
Hi Bruce,
Re: Single Panel Molded Sails
- Sail number:USA 16
- Design:Brit Pop
Thanks for asking.
Thanks for asking.
Hi Bruce,
- Design:Brit Pop
Alfonso
- Sail number:CAN 307
- Design:V8
- Sail number:CAN 46
- Club:VMSS
- Design:V8
Hi John,
Dave Alston
- Sail number:GBR3096
- Club:Market Bosworth
- Design:Fatboy
Gentlemen,
and retaining
Dave A
and retaining
Dave A
I've been thinkingAlfonso wrote:Hi John,
Peter Allen
- Design:V8
G.3.1 CONSTRUCTION
(a) MANDATORY
and
G.3.2 CONSTRUCTION TECHNIQUES
beyond the edges of the seam.
How does this approach work?
G.3.1 CONSTRUCTION
(a) MANDATORY
and
Peter,Peter Allen wrote:Ted,i hear what you're saying but i don't know what you're thinking. Peter
Ted
Hi John,
Dave Alston
- Design:Fatboy
Ted
Alfonso
Gentlemen
Alfonso
Gentlemen
- Design:V8
Hi Dave,
Dave,
Ted
Ted
Dave Alston
- Design:Fatboy
Ted,
But I digress….
But I digress….
Dave Alston
- Design:Fatboy
Roy,
Dave Alston
- Design:Fatboy
Antonio Espada
- Sail number:ESP 3
- Club:NAUTICO VILANOVA
- Design:ICEPICK
Antonio.
Antonio.
Antonio Espada
SCIRA CHIEF MEASURER
ESP 03
ESP 03
- Sail number:CRO 68
- Club:JK Opatija
- Design:Alioth V4
Hi all
Can224
Can224
Zvonko wrote:Dear all
Don Case
Can 271
Vancouver Island B.C.
Can 271
- Club:VMSS
- Design:V8
Hi Don,
Just a guess.
Just a guess.
- Design:V8
Hi John,
Dick Carver
Agreed.Nigel wrote:Hi John,
Dick Carver
