Spreaders
- GBR NCA Officer
Hi Jeolla,
D.2.1 Hull Materials
E.3.1 Keel and Rudder
F.5.1 Standing Rigging
F.6.1 Running Rigging
G.3.2 Sails
G.4.2 Sails
G.3.2 Sails
G.4.2 Sails
Andy, I think you have it right! Spreader material is not defined and so cannot be made of anything! (conversly, if the are not present, they can be made of anything )
- GBR NCA Officer
Hi John,
Yes, the Exec can instigate an emergency rule change, with immediate effect, that will require ratification at the next AGM. I believe this is what happened with Texalium the first time round.Does the class have a process that the class secretary or technical committe can make an interim ruling to cover us and provide guidance.
Hi JohnHiljoball wrote:Spreader material is not defined and so cannot be made of anything! [...] I think there are several items that fall into this hole, including other mast fittings that are not covered under the topics for standing rigging, running rigging or booms.
andIOM CR wrote:The rules in Part II are closed class rules
... we have exactly the problem you identify. In certain areas of the rules, we have the necessary permissions, for example:ERS wrote:C.3.2 Closed Class Rules
andF.6 RUNNING RIGGING
F.6.1 MATERIALS
Materials are unrestricted
Elsewhere we have a curious "kind-of" permission for terminators and swivel to be unrestricted:D.2.3 FITTINGS
But in the relevant section (F.3.3 FITTINGS), there are no explicit permissions for things like:F.5 STANDING RIGGING
F.5.1 MATERIALS
Mainsail halyard fitting
Shroud fitting(s)
Gooseneck
Kicking strap fitting
Headsail stay fitting
Headsail halyard fitting
Mainsail jackstay fittings
Mainsail tack fitting(s)
Mast strut and its fitting
Checkstay fittings(s)
Deck fitting
Added weights
And so what? My initial question arose from the simple need for some sets of spreaders for some new rigs. I then had some choices. Buy some from known sources at something like 8€ a set or produce some myself. Beeing a true DIY'er I naturally made my own. As thin-wall alu/SS tubes (especially teardrop!) aren't easy to find I therefore visited a local Hobby shop and found some nice flat CF profiles costing a few €'s a metre. Enough for 6-7 sets of spreaders.Hiljoball wrote:
JEOLLA
But the rules say 'No'.
- IOMICA Chairman
- Sail number: FRA 100
- Design: Venti
JEOLLA
