Sheet winches
Nigel28
- Sail number: CAN 28
- Design: Vancouver
Sheet winches
Nigel Ashman
CAN 328
CAN 328
Greg Vasileff
There are 2 kinds of 5801 owners,Greg Vasileff wrote:......Futaba s5801.....
I know there has been some bad rap on these, but I use 5 of them now, some for three years, and I've never had any problems.
Brad Gibson
Hi Ed,
As allways it comes down to personal preference (& what can be easily fitted to your hull
BG
BG
Hi, Ed.
I'll bet if you notify Rob that it's coming, you'll only be waiting for shipping time. He'll turn it quickly.
The Aus. Airmail is better than our USPS!. I guess it's cause we're on the west coast, but my shipping is only 3 days.
sheet winches
hi ed,
ron
ron
Jeff
Jeff
