Single Panel Molded Sails
Re: Single Panel Molded Sails
Hi Bruce,
Thanks for asking.
Thanks for asking.
Hi Bruce,
Alfonso
- Sail number: CAN
- Sail number: CAN 46
- Club: VMSS
Hi John,
Dave Alston
- Sail number: GBR3096
- Club: Market Bosworth
- Design: Fatboy
Gentlemen,
and retaining
Dave A
and retaining
Dave A
I've been thinkingAlfonso wrote:Hi John,
Peter Allen
- Sail number: CAN
G.3.1 CONSTRUCTION
(a) MANDATORY
and
G.3.2 CONSTRUCTION TECHNIQUES
beyond the edges of the seam.
How does this approach work?
G.3.1 CONSTRUCTION
(a) MANDATORY
and
Peter,Peter Allen wrote:Ted,i hear what you're saying but i don't know what you're thinking. Peter
Ted
Hi John,
Dave Alston
- Design: Fatboy
Ted
Alfonso
Gentlemen
Alfonso
Gentlemen
- Sail number: CAN
Hi Dave,
Dave,
Ted
Ted
Dave Alston
- Design: Fatboy
Ted,
But I digress….
But I digress….
Dave Alston
- Design: Fatboy
Roy,
Dave Alston
- Design: Fatboy
Antonio Espada
- Sail number: ESP 3
- Club: NAUTICO VILANOVA
- Design: ICEPICK
Antonio.
Antonio.
Antonio Espada
SCIRA CHIEF MEASURER
ESP 03
ESP 03
- Sail number: CRO 68
- Club: JK Opatija
- Design: Alioth V4
Hi all
Can224
Can224
Zvonko wrote:Dear all
Don Case
Can 271
Vancouver Island B.C.
Can 271
- Club: VMSS
Hi Don,
Just a guess.
Just a guess.
- Sail number: CAN
Hi John,
Dick Carver
Agreed.Nigel wrote:Hi John,
Dick Carver
