- Sail number: CRO 68
- Club: JK Opatija
- Design: Alioth V4
Hi Graham,
All the best
Robert
All the best
Robert
Art Prufer
- Sail number: CAN 42
- Design: Corbie 6
- Club: JK Opatija
- Design: Alioth V4
Hi Art,
All the best
Robert Grubiša
CRO 68
All the best
Robert Grubiša
CRO 68
- Sail number: CAN
Hi Robert,
- Club: JK Opatija
- Design: Alioth V4
Hi Hiljoball,
You mentioned that the proposal "changes the philosophical structure of the Materials section in a very significant way – with possible ‘unexpected’ consequences." Sorry, this sounds to me like some political phrase
Robert Grubiša
CRO 68
Robert Grubiša
CRO 68
Art Prufer
- Design: Corbie 6
I did not see any discussion with the IOM global community regarding this proposed change, at least not on this forum or on any of the other IOM sailing forums.3) Reasoning for the proposed IOM Class Rule
- Sail number: CAN
- Vice-chairman (Events)
- Sail number: CAN
The vote on this is coming soon - if you like the current closed materials list for normal construction, and think that the motion to amend materials for 3d printed hulls should have been placed in the the line item D2.1.8 Thermoplastics then vote AGAINST this item.
This motion is exactly the same as the one defeated at the last AGM, and the proposers were given lots of advice in this thread to place their request into D2.1.8 and not disturb the rest of the class materials, yet they have ignored this advice.
- Club: JK Opatija
- Design: Alioth V4
As far as I know, the main problem with the proposal on the last AGM was a fact that motion has not been explained enough, etc. Therefore, GBR representative Graham Elliot started this thread to hear the opinion of the guys using 3D print. He, and many others, let us know that there is not much wrong with the original CRO proposal.
Having now all data collected here which was not available before the last voting, it seems wise to offer to the IOM community to vote it again.
John and others worried about this proposal, why you don't help us all and asked your NCA to propose the motion which will solved this issue on this AGM? IOM ICA VC Technical is also silent...
The conclusion of the IOM Interpretation 2020-IOM-1 is clear that Class Rules D.2.1 should be improved.
Also, an interpretation is requested when it is not clear (to a designer, builder, measurer, class association or certification authority) how a class rule shall be interpreted. When an interpretation is issued it should be kept in mind that the interpretation is valid until the class rules are changed or for two years maximum only. The purpose of this last rule is that two years gives sufficient time to consider if the effect of the interpretation is a) desirable or b) undesirable. Depending on the decision or choice (a or b, by the IOM ICA) the class rules can be revised accordingly.
Art Prufer
- Design: Corbie 6
Now that this motions has passed and come into effect, it is clearly lacking in specifics and is quite ambiguous.
There is no mention of what number is used for the modulus of elasticity for the many types of fiberglass.
Nor is there any mention of what specific chart will be used to determine the modulus of elasticity of the material wanting to be used to replace FG.
There is a new discussion in the IOM FaceBook group regarding using basalt cloth for hull construction.
https://www.facebook.com/groups/iomsail ... 7565190417
Using the highest Young's number found for FG and the lowest number found for Basalt cloth, this material should be allowed.
Art Prufer
- Design: Corbie 6
I agree,Class Rules D.2.1 should be improved.Robert Grubisa wrote: 05 Dec 2021, 08:55 The conclusion of the IOM Interpretation 2020-IOM-1 is clear that Class Rules D.2.1 should be improved.
Essentially what IOMICA has done is changed a closed class rule to an open class rule. From only wood or fiberglass to any material as long as it's not stiffer than fiberglass. There are no specific numbers given for the modulus of elasticity or of what type of fiberglass, nor is there a source for the chart to be used to determine the GPa of the building material in question.
As they are written now, technically all materials must be approved by an interpretation, which as you have stated, is only valid for 2 years.
Here is just one example using the open source Wikipedia:
There are many other sites which provide conflicting information for what is shown above.
Mike McPherson
- Sail number: GBR 886
- Club: Watermead
- Design: Bubbles
forgive a silly question from someone new to all this
I have read the rules but why are cellular structures are so frowned upon?
please help me understand
many thanks
Mike
many thanks
Mike
rules must be enforceable and therefore, structures that can only be examined by destructive testing (like the interior of a honeycomb structure) should not be allowed
lets not get into the rule that specifies what grades of aluminum are allowed
Mike McPherson
- Club: Watermead
- Design: Bubbles
@BruceBruce Andersen wrote: 25 Feb 2025, 18:05 rules must be enforceable and therefore, structures that can only be examined by destructive testing (like the interior of a honeycomb structure) should not be allowed
I understand the "must be enforceable" part, but if honeycomb were to be allowed, there would be no infringement so nothing to verify
so what is it intrinsically about honeycomb that ruffles so many feathers?
it can't be a cost issue (keep it affordable so anyone can build one)
if it is purely structural or strength related, then Darwin will ensure that its use will fall by the wayside, surely?
or is it that there are so many builds out there that DON'T use honeycombed material, and they would all be suddenly disadvantaged?
thanks
Mike
PS and then I have to wonder about carbon fibre, which is becoming a common build material . . .
Art Prufer
- Design: Corbie 6
[/quote]
thanks
Mike
[/quote]
THIS ^^^
The IOM is a decades old class with a well established set of closed class rules, meaning if it's not specified in the existing class rules, then it is not permitted. In the past few years there have been a number of rule changes to allow new and improved items, some of which puts existing boats at a disadvantage. This defeats the original intent of the class by requiring older boats and designs to be upgraded to remain competitive.
There are other 'developmental' classes out there for those that want to push the envelope and participate in the 'race to the top' or 'space race'.
thanks
Mike
[/quote]
THIS ^^^
Mike McPherson
- Club: Watermead
- Design: Bubbles
ah thanks
that does make sense now
appreciate your patience!
