Number of boats to promote
Moderator: Rob Walsh
Sail number: GBR 105
Design: Pikanto
Post by Lester »
Vice-chairman (Events)
Sail number: FRA 100
Design: Venti
Post by Olivier Cohen »
Be careful!
Gilbert Louis
Post by Gilbert Louis »
Atb
Gilbert LOUIS
www.iomireland.org
V6 - RMG - Blackmagick
IRL41 - Ireland
Peter Allen
Post by Peter Allen »
Post by Steve Landeau »
It is interesting how common it is to hear about "being stuck" in the bottom heats, and how difficult it is to get out (and up). While this is true without question, one must realize that when moving more boats, it makes it easier to go down! :lol:
I was a good example; I won my seeding heat to put me in A, but I finished 14th in the second race. A 14th would have kept me in A with only 4 movers, but with 6 movers, I went down and stayed down all day! :( This certainly changed my regatta. I think it worked properly though, as I was not sailing well at the time, and did not deserve to stay in A without sailing better. I think this example proves that moving more boats will not only give more skippers a fair chance to do well, but will also pull down those that are sailing conservatively, simply to "stay in A". It is true, however, that it will reduce the amount of skippers in a full HMS format, and it also has the possibility of increasing your heat numbers. It worked perfectly for us, with 45 entries and 3 heats, we had 19 on the line every time. If we were to have 2 more entries, however, one would have to decide if you want 6 movers and 4 heats, or 4 movers and 3 heats. That decision would take some thought.
Post by Roy Thompson »
Peter Allen
Seems like most agree,i know from experience it's fairly easy to stay in A fleet if prevaling conditions are good and your boat is sailing well.I just like the idea of a gang coming to get ya from B fleet so you better start sailing agressively to stay there,as i said more action.Peter
promotion
Post by ralph kelley »
Design: Pikanto
Re: promotion
Post by Lester »
ralph kelley wrote:One must remember that the HMS system is designed to form a classification system
Hi Ralph
Design: Pikanto
Post by Lester »
EFP = (100 - A) * n
probI = ran# * f#,
so
I = (100 - A) * probI,
and finally
POS = EFP - I.
Post by Andy Stevenson »
Lester,
Sounds like an interesting project. Assuming the objective is to study the difference a different number of promotions / demotions will make and not an attempt to predict actual results :)
Post by Bruce Andersen »
Sounds great! perhaps we can determine a "skill factor" for each skipper, then virtual race all winter long. Do you think you can simulate the outcome of protests also? (note: my tongue is firmly planted in my cheek!) Happy Holidays
Post by awallin »
Hi Lester,
A nice idea !
Merry Christmas to everyone !
Dick Carver
Post by Dick Carver »
Dick Carver
Post by awallin »
Design: Pikanto
Post by Lester »
Dick Carver wrote:how do we define an "optimum" number of boats to promote/relegate ?
Hi Dick
That is certainly one approach, and would be best achieved by some kind of handicapping system I suppose.
Good points. I think I might have confused "number of incidents" with "amount of aggression on display" (smile).
Yes, this would be better.
Design: Pikanto
Post by Lester »
VCinfocomms wrote:this is the kind of analysis I was talking about
Hi Anders
The discards system could be thought of as a method of eliminating outliers -- "rogue" results which cloud, rather than clarify, the picture. What graph do you get with discards *allowed*?
Post by awallin »
Thus I would re-phrase myself: any simulation you run should reproduce these graphs, more or less, _when_run_with_4up/down_. The 'true' variability in performance that you input to the program might be different than what we see here. Hopefully I said that clearly enough ? :)
Design: Pikanto
Post by Lester »
VCinfocomms wrote:any simulation you run should reproduce these graphs, more or less, _when_run_with_4up/down_. Hopefully I said that clearly enough?
Hi Anders
Sure!
Design: Pikanto
Post by Lester »
Merry Christmas
promotions
Ralph.
Post by RoyL »
Roy
I realize that Doug is no longer with us, but could you dust off your famous "Fun-O-Meter" to add more data points to Lester's simulation?
Design: Pikanto
Post by Lester »
Have added a couple more pages. Some of the interesting findings include "discards don't matter nearly as much as promotions", and "if equal weight is to be given to all boats regardless of ability, then the more promotions per heat the better".
