winch or arm servo?
Sail number:GBR3845
Club:Eastbourne
Design:TS2 and Shiraz
winch or arm servo?
Post by Dave Pickett » 13 Nov 2010, 15:26
Neil Armstrong
Sail number:GBR 13
Design:Mallard
Re: winch or arm servo?
Post by Neil Armstrong » 13 Nov 2010, 20:38
Hi David,
Aaron Plazier
Sail number:AUS-TBA
Club:TBA
Design:TBA
Post by Aaron Plazier » 01 Dec 2010, 01:54
Dave I am no expert :P but I ordered a Hitec HS-785HB Sail winch servo for my 1st boat.
No way in same league as the RMG ones but for me it's fine to do my apprenticeship with. :lol:
Vice-chairman (Events)
Sail number:FRA 100
Design:Venti
France
Post by Olivier Cohen » 01 Dec 2010, 12:08
RMG is the easy way.
Sail number:GBR3845
Club:Eastbourne
Post by Dave Pickett » 01 Dec 2010, 20:36
HS-785HB
Sail number:USA 16
Design:Brit Pop
Post by Bruce Andersen » 01 Dec 2010, 22:54
Aaron Plazier
Sail number:AUS-TBA
Club:TBA
Design:TBA
Post by Aaron Plazier » 02 Dec 2010, 05:39
Rudder servos?
4.8v torque 8kg/cm
6v torque 11kg/cm
Patrick Parisienne
Sail number:AUS 38
Club:Albert Park Model Yacht Club
Design:Obsession
Post by Patrick Parisienne » 08 Dec 2010, 23:45
Pat
Aaron Plazier
Sail number:AUS-TBA
Club:TBA
Design:TBA
Post by Aaron Plazier » 09 Dec 2010, 11:08
thanks for that!
Ralph Knowles
Location:Dundee, Scotland, GBR1876/ GBR 2182/GBR 2167/GBR 1907/GBR 3367
Post by Ralph Knowles » 18 Dec 2010, 14:16
Bring on the Breeze!
Sail number:GBR3845
Club:Eastbourne
Post by Dave Pickett » 18 Dec 2010, 19:39
Gyula
Sail number:ROU 52
Design:Ska
Post by Gyula » 09 Jan 2011, 13:58
Gyula Ferencz
Sail number:GBR3845
Club:Eastbourne
Post by Dave Pickett » 11 Jan 2011, 19:05
