Chairman - IOMICA Chairman
Converting to 75 MHz
Post
by Chairman » 18 Mar 2004, 00:32
I hope the CAN or USA sailors can help me here. I have a Futaba 3VC Tx and the FP-R113i Rx, on 40 MHz. The Tx uses an RF module (FP-TU-FM 40), so in theory I can plug in a 75 MHz module, and if I get a 75 MHz Rx, I can sail in the USA IOM Nationals in June
Those fine folks at Tower Hobbies tell me on their Web site that they have a 75 MHz Tx RF module, part number RF-PK-FM, but it isn't clear whether it will fit the 3VC. Not too surprising I guess, since the 3VC isn't on sale in America, but it does look to be the right size and shape. I also notice that their tech notes say the crystal is pre-installed... Does that mean I can't change the crystals of Tx and Rx to avoid a clash at the pond?
Has anyone any experience of changing their Futaba Tx RF module?
Daniel - Posts:8
Post
by Daniel » 18 Mar 2004, 06:29
Hi Lester,
speak to Ken Binks, Ken sent me a 40mhz module to Australia, simply plug in the back of your trani and buy a 72mhz reciever and away you go.
I must Thank Ken for his excellent service I ordered the parts just a few days befor Xmas and they all arrived before New Year
Daniel Weizman
Steve Landeau - Posts:259
- Sail number:USA 12
- Design:Which One
Post
by Steve Landeau » 18 Mar 2004, 07:34
Lester, chances are very good that the module will fit. In europe, the same (or very similar) radios are marketed under different model #'s. I use JR, and the modules that the Euro radios have are the same casing as the ones in the US. I'd say order it and if it does not fit, Tower will accept a return.
If you cannot get yours converted, I have a spare JR that will easily program to your boat.
See you in June.
Dan Crowley - Posts:24
Post
by Dan Crowley » 18 Mar 2004, 20:23
Lester. If you, or anyone else coming to the regatta from outside the US, have not resolved this issue, please let me or Jake Leo know. I also have a spare 75 Mhz JR radio, and between the rest of us, we will be able to hook you up and get you going!
Nigel28 - Posts:82
- Sail number:CAN 28
- Design:Vancouver
Post
by Nigel28 » 18 Mar 2004, 22:04
Hi Lester I have done some reserch on this and have found the US equialent to be the 3PJ. This is a pistol grip version as that is what the car enthusiasts use. So providing the TX module fits this it should fit the 3VC.
Hope this is of some help.
Nigel Ashman
CAN 328
Post
by Chairman » 23 Mar 2004, 16:23
Thanks for your replies! Ken Binks has explained to me that the "standard" Tx 75 MHz RF module is tuned to a specific spot frequency, and (unlike our 40 MHz band in GBR) if you need a different frequency spot in the 75 MHz band, you need another RF module...
Makes it a rather expensive crystal! So I'm working on plan "B".
IanHB - Posts:30
Post
by IanHB » 27 Mar 2004, 09:26
My Question is have the USA regatta management researched the possibility of a temperory dispensation to use selected 40 Mhz frequencys for the duration of the regatta? The argument that a transmitter of such low power in such a remote locatation will not impact on any other user may carry some weight. That is unless using 40 Mhz in the US may set off WW III.
Rob Davis - Posts:58
- Sail number:USA 32
- Club:TRYC
- Design:Disco
Post
by Rob Davis » 28 Mar 2004, 06:20
I believe the organizer has contact the local air clubs and other frequencies can and will be used. If you're needing specific info contact Jake.
Rob Davis
USA 232
- Design:Which One
Post
by Steve Landeau » 29 Mar 2004, 07:53
I was checking into what the US was doing with 40 Mhz a couple years ago, and what I found was that it is assigned to "extra terrestrial communications research"....
Post
by edmorales » 29 Mar 2004, 09:49
e.t. phone home
IanHB - Posts:30
Post
by IanHB » 11 Apr 2004, 07:33
MCooper - Posts:19
Post
by MCooper » 21 Apr 2004, 23:17
Lester:
I have a JR Radio X-756. The extra 75mhz module that I have will not be used at Nationals and so you are welcomed to use if it fits your radio equipment which it probably does. I will also have a 75mhz receiver available as well to go along with the module. Just let me know if needed.
I only have a few frequencies on 75mhz but I am sure that all who will be present we will come up with something.
Looking forward to seeing you again at Nationals. Also great to see that Graham has commited to join in on the fun. It will be my first opportunity to meet and sail with him in person.
Good Sailing ~~~~~~~~~~~~~~~~ _/)
Mark Cooper
Ericca USA#199
AC USA#81
Victoria USA#150
Footy # 27
LandYacht
