Plans for a wooden IOM
Jeremy Price
Sail number: 00
Club: Wynnum Manly Radio Model YC
Australia
Post by Jeremy Price » 07 Sep 2023, 09:43
Hi all, does anyone know of any other plans apart from those below suitable for building an IOM in wooden planks, where the plans are not too out of date. Really looking for laser cut options or at least a file in pdf format that I can turn into laser cut files myself.
All I know of is the Following:
• Vickers V8 (I have built this - great files)
• Ellipsis pdf and other files available
• Equinox pdf and other files available (I have built this - great files)
• Alternative (but paper only plans which are a pain)
• Corbie 5 (paper plans only [/list]or have to pay someone in UK for laser cut stations - I'm in Australia)[/list][/list]
I understand how much work goes into the development, but was hoping for more recent plans than EG: the V8.....
regards Jeremy
Art Prufer
Sail number: CAN 42
Design: Corbie 6
Re: Plans for a wooden IOM
Post by Art Prufer » 21 Oct 2023, 22:52
Have you considered the Corbie 6 from Mirage Radio Yachts?
I have since purchased a CNC/Laser machine and would scan the plans to PDF and use Vectric Cut2D to convert them to Gcode.
The build instructions are very comprehensive and include detailed rig setup measurements.
Here is my build log:
https://photos.app.goo.gl/s1k4UTZ3d48e1Rzt9
Art Prufer
CRYA #1189 Can 42
Jeremy Price
Sail number: 00
Australia
Post by Jeremy Price » 22 Oct 2023, 07:25
Art Prufer wrote:
21 Oct 2023, 22:52
Fantastic build Art. I had considered it, then discarded, but after seeing your build I might give it a go. Thanks very much for sharing the build log. Fabulous log and reference.
My V8 is referenced here,
https://www.wmrmyc.club/latest/building-a-woodie-iom
Would it be OK to share that log in this reference article? Let me know if not.
regards Jeremy
Art Prufer
Sail number: CAN 42
Design: Corbie 6
Post by Art Prufer » 22 Oct 2023, 16:08
Hi Jeremy,
Feel free to add my Google Photo links to your web site.
Here are 2 other IOM builds I have recorded in Google Photos (note I have added comments to some of the photos).
My first build - Ellipsis...
https://photos.app.goo.gl/GMHJELrPn1TDXfeTA
This one ended up 160g overweight and had a pinhole leak, so I shelved it after the first sail.
Another IOM sailor who restored a full sized cold-molded sailboat wanted to buy it and rebuild it.
Here is my weight reduction rebuild log, removing the 1.5mm aft deck and keel/finbox. He finished the build after that and was able to get it down to 4000g. https://photos.app.goo.gl/zxstsDgaajf8LYk37
Here is my custom Equinox build for the same owner of the Ellipsis...
This was a collaboration where I built the hull, finbox, bulkhead and dry fitted the decks.
It was then finished by the new owner.
https://photos.app.goo.gl/xbLUUgmwKH3Pg9776
This is the first build I did with my newly acquired CNC/Laser cutter/engraver.
I imported the PDF of the frames into my CAM program and added 'tumblehome' to the bow frames to reduce windage and improve airflow to the jib.
We have quite a few woodies here in the Pacific Northwest.
Here is a 7 panel hard chine design by Martin Herbert, designer, builder and sailor of the Dart series of woodies.
https://photos.app.goo.gl/AjhEFkBBaddqFoNv5
(I called 'Flattie' because the bottom is a flat panel).
There are also some photos of Martin's Dart 6 on our website here:
https://westcoastradiosailing.ca/2020-news-archive/
Art Prufer
CRYA #1189 Can 42
Jeremy Price
Sail number: 00
Australia
Post by Jeremy Price » 22 Oct 2023, 23:23
Art Prufer wrote:
22 Oct 2023, 16:08
Hi Jeremy,
Beautiful Work Art. Jealous of all the woodies sailing over there.
cheers Jeremy
Stephen Robinson
Sail number: 317
Design: Tribute
Australia
Post by Stephen Robinson » 21 Oct 2024, 12:37
Hi Jeremy,
Did you end up deciding on a design?
I'm just getting back into RC sailing and I'm refitting an older boat, but down the road, I'd like to build a newer wooden design....maybe....
I see Frank Russell has a new design, Paper Clip. That might be an option for me....
I tried to send you a PM, but could not see a link.....maybe 'cause I'm new....
Jeremy Price
Sail number: 00
Australia
Post by Jeremy Price » 23 Oct 2024, 23:44
I wasnt really looking to build one, more looking to see what designs were out there.. I already have 2 woodies. I just wanted to create a blog on our club site.
Thanks for pointing out the Equinox hard chine versio.. Paper Clip. I'll add that to the article.
