Stephen Robinson
- Sail number: 317
- Design: Tribute
Stephen Robinson
- Sail number: 317
- Design: Tribute
Thanks Bruce.
Stephen Robinson
- Sail number: 317
- Design: Tribute
Thanks. Will have a look.Bruce Andersen wrote: 14 Nov 2024, 17:07 If you're determined to use a switch, use a SmartSwitch from RMG - it is sealed, shows battery charge status at a glance, and is flat to eliminate line snags
- Vice-chairman (Events)
- Sail number: FRA 100
- Design: Venti
Stephen Robinson
- Sail number: 317
- Design: Tribute
Thanks Oliver.Olivier Cohen wrote: 18 Nov 2024, 13:35 When I had an armwinch with battery connected directly to the receiver, I used a wire connected to the receiver with on the other side a plug such as XT60 to connect my battery on it. As you say, less dangerous for receiver's pins.
Art Prufer
- Sail number: CAN 42
- Design: Corbie 6
Stephen Robinson
- Sail number: 317
- Design: Tribute
Thanks Art.
