Light Air Setup....
Patrick Parisienne
Sail number: AUS 38
Design: Obsession
Light Air Setup....
Post by Patrick Parisienne » 02 Sep 2010, 04:19
Hi everyone,
Just wondering about how people go about setting up their rigs for lighter winds, and their reasoning behind it.
For example this is how I setup my Obsession:
Sails: Craig Smith
Mast: 11.1 mm Groovy
Jib boom sheeted 55-60mm out from centre of mast.
Jib downhaul slack where luff ripples are present, to encourage the draft to move aft.
A touch more topping lift (leach 40-45mm off leach line.
20mm of camber in the foot.
Main Boom centered to 5mm off mainsheet post.
Cunningham off, allowing slight puckers in the bottom panel (groovy sail)
Mast ram off, to allow the draft to move aft.
Twist so the middle batten points aft, top batten laid off, and bottom batten hooked to windward.
Shrouds loosened 2 turns on rigging screws, to help flatten the main, and reduce rig tension, can run less backstay than normal.
Backstay adjusted so the the sail is relatively flat, only a little shape in the top seam.
Rake unchanged, set-up as per Craig Smith recommendation.
I try to get the draft aft to move the Centre of Effort back, as well as sheeting the jib wider to encourage the boat to hunt the breeze, and let the rig 'breathe'....
Is this consistent with what most people run, or not?
Pat
Andy Johnson
Sail number: 3424
Club: Alton Water
Design: Obsession
Re: Light Air Setup....
Post by Andy Johnson » 23 Oct 2025, 11:29
Are you still sailing your Obsession?
Andy.
Sail number: CRO 35
Post by Zvonko » 26 Oct 2025, 05:46
I would open the jib sheet about 5 mm more and increase the jib foot depth to around 35 mm. I’d also make the mainsail a bit fuller in the upper part — as much as possible to still look well-shaped and can tack properly in light winds.
ZJ
