So far I've been using Anders file Thank you Anders with 13-23 mm spacing and 100-110 height...
Moderator: Lawrie Neish
In the 2005-2008 RRS which are available from www.sailing.org appendix E has been changed and the shortest distance between numbers on the same side is min 20 max 30 mm. (nevermind that there still is the bounding box vs. "69" problem that afaik is not solved)Gilbert Louis wrote:Hi, I am about to put my sail number on a new set of sails but I heard about recent changes in the rules about sail number, ie font, size, spacing, etc... Anyone who know the most recent version on this ??? the actual wording would be great thanking you![]()
