Reversed kicking strap
Is a reversed kicking strap (as on the 49:er) permitted?
- Sail number: CAN
The answer requires looking in a couple of places.
The issue is that a reversed kicker is working in compression.
In the IOM rule, the kicker (boom vang) is listed in the section for 'running rigging'.
If you look up 'running rigging' in the ERS (the Equipment Rules of Sailing), running rigging is defined as "only working in tension".
- Sail number: CAN
Hi Herb,Herb 3 wrote:No, IOM rule 5.5 (5.5.5 ) The kicking strap shall act only in TENSION from BELOW the main boom. Period!
To which rules are you referring? That numbering does not match the IOM rule format numbering and I cannot find such wording in my copy.
- Sail number: CAN 46
- Club: VMSS
Mike Allen
