Among AGM Resolution there is one to add lower shrouds. I already recieved lots of comments from Croatian sailors and we found that
possible adoption of this proposal will cause additional:
- cost for thin wall masts to save weight specially made and very expensive
- costs for pair of rigging screws
- cost for new pair of shrouds
- time for adjustment of rig after rig change
Explanation coming with the Resolution that:
- "lower shrouds will increase the mast behavior, so the importance of getting a high performance mast will be reduced"
- "those shrouds will improve lateral control of the mast"
are at least doubtful.
What is high performance mast? Current popular 11.0 mm/0.6 mm wall thickness alloy tube with or without spreaders is controllable with a pair of shrouds. Class rules allow you to "play" with position of shroud attachment point, spreader position, mast ram (if any) position so it is up to builder/skipper to find most useful arrangement to suit particular hull design.
Failing to understand how to tune properly a mast/rig is not a reason to change class rules and add additional rigging! Those who have a problem with lateral control of the mast with one pair of shrouds will have even more difficulties with additional pair!
We believe that IOM owners around the world will reject this proposal because above mentioned and other reasons as well.
I am open for any comments.
Zoran
CRO 69
Lower shrouds
Zoran
- CRO NCA Officer
- Sail number: CRO 69
- Club: SCOR
- Design: Kantun S
Lower shrouds
Zoran Grubisa
CRO 69
CRO 69
soeren_andresen
- DEN NCA Officer
- Sail number: 93
- Club: Herslev Strand Sejlklub
- Design: Genesis
