Files for the 2026 AGM
Moderators: Josip Marasovic, Michel Roure, Zoltan G Illes
- Zoltan G Illes
- Vice-chairman (Infocomms)
- Sail number: HUN77
- Club: DEMK
Her you can find the files for the 2026 AGM
- Proposed 2026-2 rule change 2026-2 - Measurer.pdf
- (40.11 KiB) Downloaded 5 times
- Proposal 2026-4 Stream levy AGM 26.docx
- (26.1 KiB) Downloaded 11 times
- Proposal 2026-3 of Class Championship Rules change_AGM2026.docx
- (29.82 KiB) Downloaded 5 times
- Proposal 2026-5 of Class Championship Rules change_AGM2026_FRA.docx
- (22.71 KiB) Downloaded 5 times
- Proposed rule change- Mainsail tack point.docx
- (17.69 KiB) Downloaded 7 times
- Proposal 2026-6Legibility of Sail Numbers.pdf
- (407.28 KiB) Downloaded 6 times
- Legibility of Sail Numbers 2.pdf
- (407.28 KiB) Downloaded 4 times
Re: Files for the 2026 AGM
For the proposal to change the size for sail numbering, the motion refers to replacing Appendix E8 G1.4 with numbered items (1) and (2), however the correct reference should be E8 G1 (a) and (b).
- Vice-chairman (Technical)
- Sail number: AUS 36
- Design: Blitz 6
Thanks for your comments. The wrong file was uploaded as Proposal 2026-3 - the correct file is attached and, hopefully, it has the correct RRS references. Microsoft Word can have a mind of its own on numbering
. The explanatory document (Legibility of Sail Numbers) was uploaded twice (the second time as Proposal 2026-3). Regardless of the RRS reference, it remains the best explanation of the reasoning behind the specifics of the proposed change.
- Proposed rule change 2026-3 - Sail Numbers.pdf
- (38.9 KiB) Downloaded 3 times
Thanks Andrew.
That looks much better - but now the title is incorrect - it relates to 2026-6, not 2026-3
- Design: Blitz 6
Thanks John. Corrected title and heading in the attached. I have asked Michel to distribute to the email distribution as well.
- Proposed rule change 2026-6 - Sail Numbers.pdf
- (38.58 KiB) Downloaded 2 times
