Number of boats to promote
Moderator: Rob Walsh
Post by Lester » 16 Nov 2005, 10:20
Vice-chairman (Events)
Sail number: FRA 100
Design: Venti
France
Post by Olivier Cohen » 16 Nov 2005, 11:03
Be careful!
Gilbert Louis
Post by Gilbert Louis » 16 Nov 2005, 16:30
Atb
Gilbert LOUIS
www.iomireland.org
V6 - RMG - Blackmagick
IRL41 - Ireland
Peter Allen
Post by Peter Allen » 17 Nov 2005, 02:51
Post by Steve Landeau » 17 Nov 2005, 22:13
It is interesting how common it is to hear about "being stuck" in the bottom heats, and how difficult it is to get out (and up). While this is true without question, one must realize that when moving more boats, it makes it easier to go down! :lol:
I was a good example; I won my seeding heat to put me in A, but I finished 14th in the second race. A 14th would have kept me in A with only 4 movers, but with 6 movers, I went down and stayed down all day! :( This certainly changed my regatta. I think it worked properly though, as I was not sailing well at the time, and did not deserve to stay in A without sailing better. I think this example proves that moving more boats will not only give more skippers a fair chance to do well, but will also pull down those that are sailing conservatively, simply to "stay in A". It is true, however, that it will reduce the amount of skippers in a full HMS format, and it also has the possibility of increasing your heat numbers. It worked perfectly for us, with 45 entries and 3 heats, we had 19 on the line every time. If we were to have 2 more entries, however, one would have to decide if you want 6 movers and 4 heats, or 4 movers and 3 heats. That decision would take some thought.
Post by Roy Thompson » 18 Nov 2005, 10:29
Peter Allen
Post by Peter Allen » 18 Nov 2005, 14:09
Seems like most agree,i know from experience it's fairly easy to stay in A fleet if prevaling conditions are good and your boat is sailing well.I just like the idea of a gang coming to get ya from B fleet so you better start sailing agressively to stay there,as i said more action.Peter
promotion
Post by ralph kelley » 19 Nov 2005, 16:53
Re: promotion
Post by Lester » 19 Nov 2005, 19:18
ralph kelley wrote:One must remember that the HMS system is designed to form a classification system
Hi Ralph
Post by Lester » 22 Dec 2005, 14:30
EFP = (100 - A) * n
probI = ran# * f#,
so
I = (100 - A) * probI,
and finally
POS = EFP - I.
Post by Andy Stevenson » 22 Dec 2005, 16:47
Lester,
Sounds like an interesting project. Assuming the objective is to study the difference a different number of promotions / demotions will make and not an attempt to predict actual results :)
Post by Bruce Andersen » 23 Dec 2005, 00:51
Sounds great! perhaps we can determine a "skill factor" for each skipper, then virtual race all winter long. Do you think you can simulate the outcome of protests also? (note: my tongue is firmly planted in my cheek!) Happy Holidays
Post by awallin » 23 Dec 2005, 21:38
Hi Lester,
A nice idea !
Merry Christmas to everyone !
Dick Carver
Post by Dick Carver » 25 Dec 2005, 07:41
Dick Carver
Post by awallin » 26 Dec 2005, 10:48
Post by Lester » 26 Dec 2005, 12:28
Dick Carver wrote:how do we define an "optimum" number of boats to promote/relegate ?
Hi Dick
That is certainly one approach, and would be best achieved by some kind of handicapping system I suppose.
Good points. I think I might have confused "number of incidents" with "amount of aggression on display" (smile).
Yes, this would be better.
Post by Lester » 26 Dec 2005, 12:41
VCinfocomms wrote:this is the kind of analysis I was talking about
Hi Anders
The discards system could be thought of as a method of eliminating outliers -- "rogue" results which cloud, rather than clarify, the picture. What graph do you get with discards *allowed*?
Post by awallin » 26 Dec 2005, 21:00
Thus I would re-phrase myself: any simulation you run should reproduce these graphs, more or less, _when_run_with_4up/down_. The 'true' variability in performance that you input to the program might be different than what we see here. Hopefully I said that clearly enough ? :)
Post by Lester » 27 Dec 2005, 01:36
VCinfocomms wrote:any simulation you run should reproduce these graphs, more or less, _when_run_with_4up/down_. Hopefully I said that clearly enough?
Hi Anders
Sure!
Post by Lester » 31 Dec 2005, 19:55
Post by Bruce Andersen » 01 Jan 2006, 08:24
Merry Christmas
promotions
Post by ralph kelley » 01 Jan 2006, 20:41
Ralph.
Post by Steve Landeau » 02 Jan 2006, 01:02
Post by RoyL » 03 Jan 2006, 02:07
Post by Bruce Andersen » 03 Jan 2006, 06:35
Roy
I realize that Doug is no longer with us, but could you dust off your famous "Fun-O-Meter" to add more data points to Lester's simulation?
Post by Lester » 03 Jan 2006, 23:31
Have added a couple more pages. Some of the interesting findings include "discards don't matter nearly as much as promotions", and "if equal weight is to be given to all boats regardless of ability, then the more promotions per heat the better".
