Number of boats to promote
Moderator: Rob Walsh
- IOMICA Chairman
- Sail number: FRA 100
- Design: Venti
Be careful!
Gilbert Louis
Atb
Atb
Gilbert LOUIS
www.iomireland.org
V6 - RMG - Blackmagick
IRL41 - Ireland
www.iomireland.org
IRL41 - Ireland
Peter Allen
It is interesting how common it is to hear about "being stuck" in the bottom heats, and how difficult it is to get out (and up). While this is true without question, one must realize that when moving more boats, it makes it easier to go down!
I was a good example; I won my seeding heat to put me in A, but I finished 14th in the second race. A 14th would have kept me in A with only 4 movers, but with 6 movers, I went down and stayed down all day!
This certainly changed my regatta. I think it worked properly though, as I was not sailing well at the time, and did not deserve to stay in A without sailing better. I think this example proves that moving more boats will not only give more skippers a fair chance to do well, but will also pull down those that are sailing conservatively, simply to "stay in A". It is true, however, that it will reduce the amount of skippers in a full HMS format, and it also has the possibility of increasing your heat numbers. It worked perfectly for us, with 45 entries and 3 heats, we had 19 on the line every time. If we were to have 2 more entries, however, one would have to decide if you want 6 movers and 4 heats, or 4 movers and 3 heats. That decision would take some thought.
Peter Allen
promotion
Re: promotion
Hi Ralphralph kelley wrote:One must remember that the HMS system is designed to form a classification system
EFP = (100 - A) * n
probI = ran# * f#,
so
I = (100 - A) * probI,
and finally
POS = EFP - I.
EFP = (100 - A) * n
probI = ran# * f#,
so
and finally
POS = EFP - I.
- GBR NCA Officer
Lester,
Sounds like an interesting project. Assuming the objective is to study the difference a different number of promotions / demotions will make and not an attempt to predict actual results
Hi Lester,
A nice idea !
Merry Christmas to everyone !
A nice idea !
Dick Carver
Dick Carver
Hi DickDick Carver wrote:how do we define an "optimum" number of boats to promote/relegate ?
That is certainly one approach, and would be best achieved by some kind of handicapping system I suppose.perhaps an optimum number of transfers could be defined as a number that allows a greater probability of winning the regatta for a greater number of boats
Good points. I think I might have confused "number of incidents" with "amount of aggression on display" (smile).it seems to me that the probability of incurring a penality is pretty much the same regardless of which heat one is in. Getting in trouble seems to be more likely if one is sailing in the mid-heat pack, and less likely if one is out in front or trailing the pack.
Yes, this would be better.What do you think of making the "incident" factor in a bell shaped distribution for each heat
Hi AndersVCinfocomms wrote:this is the kind of analysis I was talking about
The discards system could be thought of as a method of eliminating outliers -- "rogue" results which cloud, rather than clarify, the picture. What graph do you get with discards *allowed*?scores are from mooloolaba and vancouver. no discards when calculating the standard deviation.
Thus I would re-phrase myself: any simulation you run should reproduce these graphs, more or less, _when_run_with_4up/down_. The 'true' variability in performance that you input to the program might be different than what we see here. Hopefully I said that clearly enough ?
Merry Christmas
promotions
Ralph.
Ralph.
